ramdom oil leak + lifter question
Old Feb 28, 2009 | 07:25 PM
83cressy's Avatar
Hello. I recently did a head gasket on my 95 sl base model. The car was leaking at the valve seals enough to cause the plugs to foul every couple months. About a month after the head was done, I noticed the car would leak oil randomly. sometimes it will be fine for a month, then the next week it will need two quarts. Any suggestions? I am thinking something pressure related? Also does anyone know what way the lifters are supposed to go in the head. My friend knocked them over and I couldn''t tell which way the oil hole used to point. Seems to run fine now but there is a slight tap. Thanks all.
Old Feb 28, 2009 | 09:21 PM
On the early SOHC engines, rotate the lifters until the flat sides are parallelto the intake and exhaust manifold flanges and install the lifter guide plates ....
91esgt-sl2
Feb 3, 2013 10:56 PM
mikel200
Jan 24, 2008 10:54 PM
NFGrocks1028
Aug 16, 2007 12:56 AM
96_SC2
May 25, 2007 04:36 PM
nate54
Jul 12, 2006 12:08 AM
