ramdom oil leak + lifter question
Hello. I recently did a head gasket on my 95 sl base model. The car was leaking at the valve seals enough to cause the plugs to foul every couple months. About a month after the head was done, I noticed the car would leak oil randomly. sometimes it will be fine for a month, then the next week it will need two quarts. Any suggestions? I am thinking something pressure related? Also does anyone know what way the lifters are supposed to go in the head. My friend knocked them over and I couldn''t tell which way the oil hole used to point. Seems to run fine now but there is a slight tap. Thanks all.
