Radiator fan won't start even with a/c on?
Old Mar 16, 2011 | 01:04 PM
annedonnell's Avatar
Default Radiator fan won't start even with a/c on?
I have a 2001 saturn sl1 series. I have been having some overheating problems with my saturn. My shop said that the ects was bad, and I just recently replaced that. My neighbor and I noticed that my radiator fan doesn't come on even when the a/c is turned on. Should the radiator fan turn on when the a/c is turned on regardless of the engine temp?
Old Mar 16, 2011 | 08:56 PM
Yes it should. Run a set of test leads directly from the battery to the fan to make sure it will work .......
Old Mar 21, 2011 | 07:27 PM
andre's Avatar
the a/c fan will not run if the refrigerent is low on the a/c system
Old Mar 21, 2011 | 08:04 PM
stratman3's Avatar
I have a 96 SL2 with the same problem, the a/c compressor comes on but no radiator fan. So far I changed the fan motor, the colant temp sensor, and swaped the relay with another one. Still nothing, what am I missing? Could the ECU gone bad?
Old Mar 21, 2011 | 09:19 PM
check for 12V at fan connector with A/C compressor engaged
tikidude
Aug 30, 2014 05:04 PM
gregdorie
Apr 28, 2012 02:27 PM
Nate_D33
Jun 30, 2010 09:52 PM
2002sc2
Feb 27, 2010 09:13 PM
redcannon
Jun 10, 2007 04:11 PM
