No spark
Old 12-21-2009, 12:45 AM
NascarFanSS's Avatar
Default No spark
My 97 Saturn stalled out initially it restarted after 5 minutes. I drove it home but the next morning it wouldn't start and hasn't since. My plugs and wires are okay but there is no spark. Replaced the crank shaft positioning sensor and spark plate, and the coils are good. My timing chains fine. My mechanic believes it is a bad pcm but isn't sure and recommended the dealership. I hear a bad pcm is uncommon. I live far from a dealership and I really want to avoid the giant tow bill...I'd appreciate suggestions.
Old 12-21-2009, 06:29 AM
Did you check spark on all plugs?
Did you replace with new CPS or used one? Check to be sure replacement one is in spec....
Did you trace elec connection from CPS back to PCM?
How'd you check coils and plug wires?
And what's a spark plate?
(Just tryin to be thorough...)
petes343434
02-15-2020 10:51 AM
hartman
06-16-2008 10:44 AM
mathieuhouston2
01-27-2007 10:24 AM
Turbochump
12-09-2006 01:25 PM
hierophant
08-31-2006 01:21 AM
Quick Reply: No spark
