Need some help and advice.
Old Mar 19, 2019 | 09:24 PM
Erik13's Avatar
Default Need some help and advice.
So my stock reservoir tank for the radiator on my 93 Saturun SL has a lick. I was wondering what other type other tank I could use???....... I'm.looking for something different. Thank you
Old Mar 20, 2019 | 08:14 AM
Get some JB Weld wet repair and fix the lick. It's a putty that you mix together with your hands and then apply. The surface HAS to be CLEAN in order for it to stick and work.
Old Mar 20, 2019 | 09:20 PM
Sorry you said reservoir tank not radiator
Unless you can find another reservoir tank that comes with the required coolant level sensor pressure switch that the PCM is monitoring, you're kind of locked in there. If it has a leak by one of the seams, replace it before it explodes while you're driving. It has happened. I'm not joking. It's 26 years old and dry rotted plastic. Buy a new one while you still can. If it's a hole from rubbing on the car, well...
SaturnGirlFromMars
Oct 11, 2018 02:45 AM
rpgibbs
Oct 16, 2013 12:22 AM
Citizen Zero
Dec 29, 2010 08:40 AM
Cold1212
Jan 25, 2009 09:38 PM
arfalberg
Jan 13, 2006 01:34 PM
