many replaced parts no success
Old May 2, 2008 | 10:13 PM
cordytess's Avatar
1998 Saturn SL single cam, have replaced the map,throttle, and oxygen sensors, also new fuel filter, oil filter, air filter, and new wires and plugs, new PC valve and new water pump. What the car does is it is hard to start, hesitates badly, lacks power, and has a low idle of 600 to 800. Has a check engine light on and the code is P0171. It sometimes gets better when it has warmed up but yesterday the symptons got so bad we had to tow the car home. Any ideas of what to do?</font>
Edited by: sw2cam
Old May 3, 2008 | 11:46 AM
Temp sensor and connector.
Old May 3, 2008 | 01:13 PM
Low Saturn's Avatar
Yep, sounds like a coolant sensor problem.
The P0717 is also a front O2 sesor code. A bad temperature sensor can be causing the engine to run rich, causing your described problems and either fouling the O2 sensor or confusing the PCM into think it's bad.
Old May 3, 2008 | 07:44 PM
cordytess's Avatar
Okay I replaced the coolant sensor and connector and it still is bad and still hesitates. Any other suggestions,
I haven't replaced the EGR valve, could that be it?
Thanks
Old May 5, 2008 | 09:21 AM
Low Saturn's Avatar
Did you check for spark at the coil packs?
Old Sep 5, 2009 | 04:07 PM
SaturnSl1?Sl2?'s Avatar
Hello i have a saturn sl1 with basicly the same problem it starts hard, and lacks power on the low end. Ive replaced the plugs and wires, the whole top end is rebuilt, and everything is stock in the engine catagory, Any idea on why i have no low end power and hard starts, sometime it takes two to three times to start.
Old Sep 5, 2009 | 04:10 PM
Also the car is 5 speed
Old Sep 6, 2009 | 02:16 AM
casacano's Avatar
I just changed my EGR valve becsuse the car would start to stall when I let off the accelerator to stop at a light or stop sign. I tried everything before that like you, but the EGR fixed mine. I did not have any loss of power on the vehicle.
dredawg10
Oct 10, 2013 07:19 PM
Aug 5, 2007 07:04 AM
redsaturn97sc2
May 19, 2007 09:21 AM
sgm81
Dec 21, 2006 09:48 PM
SL2ofDoom
Aug 11, 2006 10:40 AM
