Key Stuck. Can't Shut Engine Off.
Old Mar 6, 2017 | 11:05 AM
Bigby's Avatar
Default Key Stuck. Can't Shut Engine Off.
I started the car, but now I can't turn the key back and shut off the engine. The engine is still running. Is there anything i can do?
It's a 92 Saturn SL1 automatic
Old Mar 7, 2017 | 07:25 AM
You might try LIGHTLY tapping on it with a hammer. IF that doesn't work, just disconnect your battery ground cable. If that does work, try putting some graphite in the ignition cylinder and rotating the key back and forth a few times. This will lubricate the tumblers in it.
Old Mar 7, 2017 | 09:41 AM
Per Rube,
Powdered graphite in small tubes are available at Lowe's and Home Depot.
Ask someone from the lock/key dept.
Old Mar 7, 2017 | 04:39 PM
Bigby's Avatar
Thanks for the help. Disconnecting the battery stopped it. I couldn't get the cylinder to move like it should so it looks like it'll be a replace job.
Old Mar 9, 2017 | 11:54 AM
See if you can find a kit with the removable tabs for your original switch. You simply disassemble the old one, one tab at a time, clean off the old one and check the # or letter on it and put in a new one with the same # or letter. After you get them all in, your old key should still work in the switch. If you can't find a kit like that, then you'll just have two keys on your key chain, instead of one.
jethika
Nov 6, 2016 01:56 AM
mgordonb
Sep 13, 2010 06:05 PM
kaylapuppy
Sep 12, 2010 10:19 PM
earthquakes
Sep 24, 2008 08:51 PM
TCPAUL
Mar 17, 2008 09:27 AM
