Ignition key stuck in position intermediate between "lock" and "accessory"
Old Nov 29, 2025 | 04:09 PM
Do NOT use the worn key for anything except a necklace.
Unless you wish to be replacing your hardly worn door locks and trunk lock. The other locks are not as worn internally as the ignition, so the key will be even more of a mismatch. The more you try to force it with the old key in the other locks, the faster you damage the other locks.
Keep it as an emergency.
You can try getting a key cut from the VIN number, but the locks have enough wear that a brand new vin cut key May actually not work. That sentence contains multiple grammatical errors. What I did for my 95 was to take an original worn Saturn replacement key and found a hardware store that still had a manual key grinder and thankfully an experienced key cutter. He traced both sides of the key and cut them manually so to speak like in the old days. Spot on for the locks in their current condition.
Old Nov 29, 2025 | 04:11 PM
sseibel's Avatar
Got it. I will look through all my keys for what seems to be the best one and set it aside for safe keeping and use copies of it for the doors and trunk and avoid using the other multi-generation worn-out copies.
Rootmazur
Nov 22, 2024 09:09 AM
geeve420
Aug 22, 2021 10:50 PM
spartan89
17
May 25, 2015 10:47 PM
shannon39
Feb 29, 2012 08:16 PM
packet
Aug 16, 2011 07:09 AM
