If a starter problem is highly temp-dependent, is that a clue?
Old Feb 26, 2025 | 07:43 AM
sseibel's Avatar
Default If a starter problem is highly temp-dependent, is that a clue?
Starter consistently fails to crank at all when engine is warm, works when cold. Just started having problem 2 days ago. Planning to change starter today -- is that probably the right thing to do? Is the temp-dependent nature of problem common, and does it give any helpful clues?
In the failed attempts, panel lights dim showing high current draw, but only a slight brief noise from starter, engine is not cranking at all.
'97 SL1
Old Feb 26, 2025 | 08:09 AM
Sounds like a weak spring in the bendix on the starter to me. It engages the flywheel but won't spin it over. Disconnect the ground cable and check the connections on the starter for corrosion first, though. It might be that simple. How many miles are on the car?
Old Feb 26, 2025 | 08:41 AM
sseibel's Avatar
About 180,000. But the starter may have been changed before, I can't remember, have records somewhere but can't locate right now.
Old Feb 26, 2025 | 11:01 AM
grcauto8453's Avatar
I don't just throw parts at a problem. Test things.
When it does not start you need to apply 12 volts to the relay and see if it cranks. If it does the relay may be your problem. Do you have a meter?
Old Feb 26, 2025 | 12:47 PM
sseibel's Avatar
Yes I do --
Old Feb 28, 2025 | 10:22 AM
Start at the relay. The entire manual is here. Just click in the breadcrumbs.
Home >> Saturn >> 1997 >> SL L4-1.9L SOHC VIN 8 >> Repair and Diagnosis >> Starting and Charging >> Starting System >> Starter Relay >> Diagrams
Starter Relay: Diagrams
Starter Relay:
Old Mar 1, 2025 | 10:13 PM
sseibel's Avatar
Thank you --
Old Mar 2, 2025 | 03:54 AM
sseibel's Avatar
Well changing the starter has apparently fixed the problem; couldn't replicate it afterwards even when car was warmed up. The small 10 mm nut came off so easily I almost wonder if it was slightly loose but that wouldn't seem to mesh with the fact that I never (yet) had had any problems starting when the motor was cold. Anyway it is working now --
Old Mar 2, 2025 | 06:29 AM
Another one back on the road
Stove
Nov 19, 2024 08:00 AM
yaazh
Saturn Aura
20
Oct 3, 2024 10:27 AM
cb1987
May 25, 2010 05:19 PM
xtremezx2
Feb 13, 2007 11:07 AM
jasontut
Feb 6, 2007 09:15 PM
