engine swap
Old 07-04-2007, 12:45 AM
5inchdrop's Avatar
i have a 92 sl2 and i was wondering wut years of engines are interchangable. help please.
Old 07-04-2007, 07:00 PM
Low Saturn's Avatar
1991 and 1992. If you put a 1991 engine in, you'll need to install a 1992-1998 timing chain cover.
Old 07-05-2007, 12:39 AM
5inchdrop's Avatar
alright thanx. i think i will just keep an eye out for another 92 so i can just bolt it in. would it cost alot to rebuild a pretty warn out twin cam? and r parts easy to find?
Old 07-06-2007, 05:50 PM
honda-hater-sl's Avatar
If you have a 92 that was leftover stock from 91 you can swap directly. If you have a motor mount on the left side of your valve cover bolted to the top of the timing cover then you need to keep that timing cover AND valve cover to put them on a 91. if you DONT have that mount it will swap straight over.
Old 07-10-2007, 12:44 AM
5inchdrop's Avatar
ok thanx. i have the upper mount.
Old 07-16-2007, 11:32 PM
5inchdrop's Avatar
is the timing chain cover and valve 1 thing or 2 seperate parts? i havent really looked close.
MengusDew
04-04-2007 02:39 PM
Lastdefense05
09-05-2006 02:37 AM
bugshield
06-17-2006 10:15 PM
thoken
06-13-2005 10:27 AM
jschrader
05-11-2005 07:19 PM
Quick Reply: engine swap
