Engine Codes
Old Nov 21, 2006 | 07:51 PM
S-Turn's Avatar
I've becomeused to the orange glow of my check engine light but out of curiosity I ran the codes on the car and one was the O2 sensor and the other was the "quad driver." Anyone have a clue what the quad driver might be?
Old Nov 21, 2006 | 08:25 PM
STLWACO's Avatar
What year and model?
Edit: I searched your posts and found you have a 1992 SL
Quad Driver is built into the PCM of the vehicle. To correct the concern the PSM would need to be replaced.Edited by: STLWACO
Old Nov 21, 2006 | 11:07 PM
Nonsense. Quad driver output fault is a generic code that covers a bunch of stuff that share a single "flag". A problem with any one of the systems hanging off of the this circuit will set the same code.
I'm yet to see a single quad driver output fault require a PCM replacement.
IM me and I can share the sometimes gory details of troubleshooting it, or search for quad driver in this forum and you should find a post or two by me concerning troubleshooting this code.
Based on age of car, I'll blindly guess your EGR needs cleaning.
Derf
Old Nov 22, 2006 | 11:57 AM
S-Turn's Avatar
Thanx for the help! I looked at some of your old posts and it looks like other people fixed the problem just by cleaning the EGR, so i'll give it a try
Old Nov 22, 2006 | 02:48 PM
STLWACO's Avatar
Derf
Old Nov 22, 2006 | 09:28 PM
Folks,
I should have been more specific in my response -- indeed, the quad driver is an integrated part of the PCM. Simply pointing out that getting a quad driver related code on a Saturn S car
almost hardly pretty much never ends up upon proper diagnosis</span> to be the quad
driver itself that is the problem.
In theory--sure--could happen -- and indeed you'd need to replace the PCM.
In practice --
yet to see it.
Sorry if I came off a bit harsh -- I had a shi*t day at work.
Ultimately -- I hope you problem will be solved with our assistance.
Derf
Old Nov 23, 2006 | 01:20 AM
S-Turn's Avatar
off topic, but curious... what program is pictured in the screenshot? Is it just used for referencing automotive jargon?
Jan051
Mar 18, 2012 07:16 AM
imabooger
Aug 5, 2008 08:42 PM
AudioPhyle
May 30, 2007 01:48 PM
z4me95
Sep 25, 2006 10:15 PM
calmb4dastorm
Jul 7, 2006 12:11 AM
