Engine Code Help!!
Old Aug 7, 2008 | 06:28 PM
bigdezy419's Avatar
Ok so today im driving my 2002 Saturn SL1 and the service engine soon light comes on. I drive it to my mechanic and he uses his computer and it says its pulling 2 codes one is:
P0128
and then the other one says P0128 pd..
Ive looked around on the computer and ive seen something that says Insufficient Heat? help me out please. thanks
Old Aug 8, 2008 | 11:22 PM
Did a bit of poking around on the net. . . .
PCM is sensing that the coolant temp is not reaching a high enough temp within a certain amount of time after start up.
So I suspect either the ECTS is giving a low temp reading to the PCM, or the thermostat is malfunctioning and the coolant in fact is not heating up as quickly as it should.
Have seen quite a few posts on this elsewhere for Vues but not the S cars.
ECTS failure usually comes with all kinds of other bonuses, like hard starting, crappy fuel economy, bogging under acceleration, etc.
Guessing the thermostat, but check ECTS first anyway.
codyj88
Jan 7, 2013 02:06 PM
james clark
Feb 23, 2011 09:24 PM
Curly
Apr 4, 2010 06:28 PM
Mike1288
May 23, 2008 04:32 PM
mikes 1994 z28
Aug 9, 2006 09:08 AM
