Door switch replacement
Old Jan 28, 2013 | 11:00 AM
Johnboy2978's Avatar
Default Door switch replacement
Hello all. I have a 2001 SL2 and for the past 6 months or so, I've had an intermittent issue w/ the door locks. The rocker door lock switch on the driver side seems faulty. At times, it will not correct itself and lock/unlock repeatedly until it drains the battery. I'm assume I can just replace the switch itself ( http://www.ebay.com/itm/SATURN-SL1-S...1bff2a&vxp=mtr ) and not the whole handle lock switch ( http://www.ebay.com/itm/Saturn-S-Ser...0105f0&vxp=mtr ) correct? Does that piece just pop out of the handle unit?
Thanks
Old Jan 28, 2013 | 12:17 PM
Kinda looks like from the pictures, dontcha think?
Old Jan 28, 2013 | 01:38 PM
Yes, it does appear that way. I was just looking for some confirmation from someone else who has experienced this, that I only need to replace that one part and not the whole panel.
Old Jan 28, 2013 | 02:13 PM
The pictures make it rather obvious...........................
Old Jan 29, 2013 | 08:54 AM
I'm not sure if the Saturns have a separate BCM (body control module) but if so, check your connector for corrosion or a loose wire. The BCM usually controls this function.
Old Jan 31, 2013 | 07:53 AM
Ayup -- I'd check my connections first too. Hate to spend money on parts I don't need...
Old Feb 4, 2013 | 07:46 AM
well, got the part (just the lock) and changed it out in about 5" and all seems to be functional now.
Old Feb 4, 2013 | 09:49 AM
excellent
sldood
Apr 6, 2014 10:37 AM
deeprig9
Jul 21, 2013 05:31 PM
Rubehayseed
Oct 23, 2011 10:00 PM
easonfamily9
Sep 8, 2011 07:59 AM
marky
Oct 11, 2008 11:15 PM
