Check Engine Light
Old Apr 20, 2011 | 08:54 PM
hclinton's Avatar
Default Check Engine Light
I have a 2000 S and the check engine light stays on. I have checked everything I can think of and find nothing. It runs fine except randoming it idles fast, other times it idles normally. New to Saturns.
Old Apr 20, 2011 | 09:54 PM
go to autozone or similar. get codes read. post actual codes (Pxxx) here and we will troubleshoot
Old Apr 20, 2011 | 09:57 PM
Idle Air control valve/sensor maybe?
Just throwing it out there since I just replaced my throttle body that was one of the sensors on it, I had to disconnect it when adjusting idle and when the hole got unplugged it idled faster than normal, and the check engine light was turned on. It might be going.
I could be wrong though.
Old Apr 20, 2011 | 10:00 PM
Old Apr 21, 2011 | 12:20 AM
Very difficult to diagnose without knowing what failure codes are showing up ......
Old Apr 21, 2011 | 06:17 PM
Old Apr 21, 2011 | 09:33 PM
hclinton's Avatar
Default Thank You.
I will go to Auto Zone tomorrow and have it tested. Thank you all for your advice.
waterdish
May 29, 2009 11:32 PM
markdonn
Jul 4, 2007 07:03 PM
rockcandy
May 19, 2007 05:35 PM
zachary1988
Oct 20, 2005 03:22 PM
rufusnruby
Aug 6, 2005 10:54 PM
