98 SL2 load vibration from engine?
Old Jun 29, 2007 | 02:07 AM
john e.'s Avatar
my 98 SL2 has aload vibratin that vibrates the dash inside the car. Seems to comming from somewhere near the back of the engine? onthe passenger side. Really bad when car is idleing ond in park. Ever worse when its cold! need help!
Old Jul 1, 2007 | 12:32 PM
Top motor mount is the most common.
Old Jul 1, 2007 | 11:17 PM
garyb's Avatar
I agree with sw2cam. I had identical problem in my 92 SL2, replaced top motor mount, and problem was solved. I was also pleasantly surprised at how easy it was to replace top motor mount in Saturn, using directions from this forum. I recommend OEM Saturn replacement mount, as there was a difference in quality from aftermarket imports replacement mounts.
Old Sep 23, 2010 | 07:52 AM
navypcc's Avatar
Default Top motor mount replacement
I just replaced the top motor mount on my 2000 Saturn SWP last week after having problems with the engine shaking while idling. The dealer pointed it out on a visit to Saturn. They wanted $200 to do the job which I really didn't have. After doing some research I purchased a new motor mount from Theautopartsshop.com for $18.05 plus shipping and I found several video's on YOUTUBE showing how to do the job. It only took me about 10 minutes using just a 15MM socket wrench. It solved the problem. Here's the video I watched.
http://www.youtube.com/watch?v=zaugUfILmGE
Attached Thumbnails 98  SL2  load vibration from engine?-91-17-2010-old-motor-mount-1-.jpg   98  SL2  load vibration from engine?-91-17-2010-old-motor-mount-2-.jpg
Old Sep 23, 2010 | 05:54 PM
Uh huh -- top motor mount is normally the culprit ...........
Old Dec 19, 2020 | 11:07 PM
Thumper Simpson's Avatar
I thought mine would be top engine mount but noise is coming from fan area (08Vue)
Old Dec 20, 2020 | 09:07 AM
are you referring to the exact 10 year old noise mentioned in this post?
Upper Torque axis mount (TAM) on pass side does this.
Loses isolation betw engine and frame and shakes the bejesus out of the vehicle.
OEM ones are the only good ones nd they are no longer made.
All aftermarkets suck.
The less you pay, the less you get.
And whatever you do put on will not kill all the vibrations. They really do suck.
Some people scan junkyards for used OEM TAMs that are not trashed b c they are usually better than the new aftermarket crap.
How much money in guaranteed revenue did GM **** away by stopping production?
Old Dec 20, 2020 | 01:30 PM
are you referring to the exact no vibration, 10 year old noise mentioned in this post?
Just a loud flapping noise at startup or when accelerating. No vibration.
Old Dec 21, 2020 | 01:55 AM
Oh I see the issue.
You tacked an 08 Vue flappy startup noise onto an S series vibration post from a decade before.
So i revise my response to
a) why is this posted on the end of an unrelated s car thread?
B) I don't understand your answer to a post for a different model car that has an unrelated issue
c):there is a Vue section. Use it
JDC
Jun 9, 2014 09:44 AM
john doe
Feb 7, 2013 10:38 AM
GRETSCH43
Feb 8, 2010 07:56 AM
tonygarcia1990
Jan 7, 2010 09:08 PM
jamienfld
Aug 20, 2007 01:53 PM
