97 SC2 missing at speed
Old Sep 14, 2009 | 07:55 PM
kens's Avatar
Default 97 SC2 missing at speed
I can't find a post describing this--
Engine runs beautifully at idle and up to 1800 rpm as well as above 2200 rpm. If you accelerate even moderately between 1800 and 2200 rpm (40 to 55 mph) the engine hesitates, spits and coughs a bit. Below or above those speeds even hard acceleration does not induce the hesitation.
Thought at first it was the fuel pump, filter, pressure regulator problem that is described by others for these cars. Filter and pressure reg have been replaced with no benefit.
I will do the fuel pump if no other ideas come to light but wanted to check with all you pros on the forum before doing so in case there are other ideas.
Old Sep 14, 2009 | 08:44 PM
change ects (brass style replacement) and connector (dealer only)
Old Sep 21, 2009 | 12:52 PM
GRETSCH43's Avatar
I have a 93 SL3, last year engine would miss when accelerating at cruise speed. Turned out to be spark plug wires. Might give that a try. New set costs around $35.
BRG'sFSTSL1
May 19, 2008 06:55 PM
lomfs24
Jun 1, 2007 11:38 PM
chamberland_666
Apr 1, 2007 05:05 PM
Briad
Feb 20, 2007 03:08 PM
tiny747
Oct 29, 2006 06:52 PM
