92 sl2 hard starting
Old Mar 20, 2011 | 12:28 PM
4x4troy's Avatar
Default 92 sl2 hard starting
i have to floor it for it to start.once started it runs good but....it will stall sometimes when i go to go or come to a stop.it has a new tps and iac.i am going to replace the map and coolant temp sensor.anybody have any ideas on what it couild be?
its a 1992 sl2 with a dohc and 5 speed
Old Mar 20, 2011 | 12:43 PM
Do the coolant temp sensor first, then re-evaluate ....
Old Mar 20, 2011 | 12:55 PM
4x4troy's Avatar
ok thanks
Old Mar 21, 2011 | 04:35 PM
4x4troy's Avatar
still stalling and smelling fuel,but only before it stalls.could the map be the villian?
Old Mar 21, 2011 | 05:02 PM
4x4troy's Avatar
ok the car will only start if i floor and hold down the gas pedal before i trying to start it.it will start and run.when i let off the pedal sometimes it will stall sometimes keep running.it will then idle just fine and sound real good nice and smooth.once you go to take off...as in press the gas pedal it stables almost stalls,gets a strong fuel smell and will sometimes if i feather the throttle it will pick up and go,other time it will just stall.it will start right back up doing the floored pedal thing.i have replaced the tps,iac and coolant temp sensor,helpped alittle but still does it.could the map be the cause here/ what about the egr valve?please help before i send this thing to the junkyard.
Old Mar 21, 2011 | 05:55 PM
check the vac line to the EGR
Also, if you've never cleaned the EGR, and it's original, and you burn oil, it needs cleaning anyway.
make sure you get a hold of an other EGR gasket before you pull it -- the 19 year old one in there will likely not be reusable
Old Mar 21, 2011 | 07:24 PM
andre's Avatar
can be the vacuum line to the fuel return regulator valve , make sure you have a good 40 psi on the fuel rail to the injector.
Old Mar 21, 2011 | 09:45 PM
yes indeed check that too
son's sl2
Jul 30, 2010 08:30 PM
cobra248
Jul 19, 2008 11:53 AM
retiregoal
Mar 5, 2008 06:33 AM
sgtlake
Sep 14, 2007 11:11 AM
William1907
Jul 8, 2006 09:41 AM
