1999 saturn sl2 help
Old May 17, 2006 | 03:58 PM
ohurt63's Avatar
wants to flood cylinders with gas on start up, hold it to the floor and it clears out, need help with problem, already replaced fuel preasure regulator thanks
Old May 17, 2006 | 07:47 PM
starchief1959's Avatar
I would check injectors, they may be siphoning gas into the cylinders after you shut the car down.
Old May 17, 2006 | 09:21 PM
ohurt63's Avatar
found out engine temp sensor was bad replaced it,fixed the problem thanks
Old May 18, 2006 | 11:14 AM
No Kidding? Wow, would never have thought a temp sensor could do that. I suppose being everyting is computer controlled now, just about anything can happen.
Thanks for the update.
Old May 23, 2006 | 01:08 AM
The temp sensor can cause many hard start, no start, and bad running problems it's not funny. It is what sends info to the computer that tells it to turn the cooling fan on or off. It tells the computer the engine operating temp. If the computer thinks the engine is cold it sends more fuel. If it thinks the engine is hot it sends less fuel. If the temp sensor has been seeping also replace the conntector.
chuxk79
Dec 9, 2014 08:49 AM
Bobbed06
Feb 22, 2012 10:41 AM
itsamanda31
Nov 19, 2010 07:29 PM
prabhakarglv
Jun 7, 2009 02:20 PM
