Ignition Lock cylinder Won't Come out
Old Jun 21, 2018 | 10:04 AM
MikeGlosta's Avatar
Default Ignition Lock cylinder Won't Come out
2003 LW300
Trying to replace ignition lock cylinder:
Key on Run, tab pushed in but cylinder doesn't release
When I try to pull out cylinder it feels like a tumbler or other part is blocking its removal.
Any ideas on how I can try to maneuver the cylinder out?
Thanks
Old Jun 21, 2018 | 05:31 PM
Is there any way you can push the tab in any further, Mike? IDK, just asking. Seems if you have it pushed in all the way, it should release.
Old Jun 21, 2018 | 05:51 PM
MikeGlosta's Avatar
I've pushed the tab in as far as it can go, the cylinder sprung and came out about 1/8" - then became blocked from coming out further. I'll keep working at it ....
Unless someone makes a reasonable offer and take the car off my hands.
Thanks for the reply
Old Jun 21, 2018 | 10:25 PM
The fsm says to rotate the lock cylinder to start. While rotating cylinder back to the run position depress the locking button. The cylinder should slide out then.
Old Jun 22, 2018 | 04:18 AM
MikeGlosta's Avatar
Thanks, I'll give that a try this morning. Wasn't aware I had to key to 'start-rotate-push tab-run'
Old Jun 22, 2018 | 06:12 AM
Andy IS the L Series guru, Mike. I'm sure that'll probably work for you. Proper procedures are usually the best.
geeve420
Aug 22, 2021 10:50 PM
jspen
Oct 8, 2017 11:30 AM
Nopaynenogayne
Dec 21, 2013 10:36 PM
mpace001
Oct 24, 2012 09:57 AM
richie6
Jan 13, 2009 02:15 PM
