Help please
Old 02-08-2022, 07:38 PM
Dawnpatrol219's Avatar
Default Help please
Not the issue. I have the correct bulb. I just cant seem to get the bulb in the cradle. I know I sound like an idiot but I've tried everything.
Old 02-09-2022, 09:06 AM
lrbraner's Avatar
I had that problem once.
Turned out the new bulb was longer than the original.
Old 02-11-2022, 11:28 AM
Not that problem. I have the correct bulbs. I just cant seem to get the bulb seated in its cradle. I know I sound like an idiot but I am seriously having a problem.
Old 02-11-2022, 02:12 PM
Please post a photo with the bulb in as far as you can get it so we can see exactly what you are working with. Use the icon it looks like a picture above where you type text to post
Old 02-11-2022, 02:15 PM
Also, given the age of the vehicle, there may be corrosion in the socket that is literally taking up part of the gap where the bulb is supposed to fill. You may need to send the metal parts at the base and on the tab inside the socket. Obviously do not do this while the light is supposed to be on unless you like getting zapped.
Did you have an excessive amount of trouble removing the bulb previously in there?
ehusmann
12-11-2020 08:48 AM
lrbraner
01-21-2020 10:44 PM
lrbraner
09-28-2019 07:26 PM
drosselmeyer
Saturn L300
12-20-2010 10:14 AM
brags
07-02-2010 11:48 PM
Quick Reply: Help please
