where is my crankshaft timing maek tab
Old Oct 16, 2015 | 11:35 AM
343's Avatar
343
Default where is my crankshaft timing maek tab
hi I have a 2000 Saturn ls2 3.0 engine and I would like to know is where is my crankshaft timing tab mark on engine or is it on the left or right side of engine this is engine vin no(G8JW2R6YY675242) with pictures if possible the timing tensioner froze up timing belt slip timing is off
Old Oct 16, 2015 | 10:10 PM
All timing marks are behind the timing belt cover. There are repair manuals in the forum/general/general tech help section. If the timing belt jumped time you will have bent valves also. Sorry.
Old Oct 16, 2015 | 10:23 PM
moved to L series section.
Never worked on an L car myself, so I'm not of much use on this one. Someone else should come along and chime in.
A Haynes or similar manual would prob help you out with the whole timing procedure. Usually money well spent.
Old Oct 16, 2015 | 11:39 PM
tooter1's Avatar
Old Oct 18, 2015 | 04:06 AM
343's Avatar
343
sorry.. I forgot to say car was running and the timing belt was remove before set cam timing marks were set as for as I know no bent valves
Old Oct 18, 2015 | 10:04 PM
so you were replacing the timing belt as preventative maintenance?
I'm not making fun of your typing or english language skills or anything like that -- I just don't understand what you're trying to say.
benlomand
Oct 26, 2009 11:54 AM
beeunit20
May 30, 2008 10:18 AM
mpk4580
Jan 25, 2006 08:09 AM
B3SL1
Aug 4, 2005 09:49 AM
RonRon
Apr 5, 2005 02:57 AM
