saturn wont start
Old Jul 15, 2012 | 12:28 PM
davidbloom's Avatar
Default saturn wont start
I need help with my 2000saturn saturn ls 2.2 twin cam it wont start has spark but it is yellowish and has fuel pressure is good but it wont start changed the plugs and crank sensor also changed the collent senor and fuel pressure reg i dont know where to look now
Old Jul 15, 2012 | 05:39 PM
Yellow spark indicates bad coils to me. But I don't know if your car has a single coil or if it has multiple coils. I'm not familiar with the DOHC engine at all.
Old Jul 15, 2012 | 07:02 PM
Make sure the battery is fully charged, and that the connections to the battery are clean and tight. Has this non-starting problem been sneaking up on you, or is this "all of a sudden" ??
Old Jul 16, 2012 | 05:20 AM
davidbloom's Avatar
Battery is good and this prolem was all of the sudden i was checking the spark plugs
Due to lack of power and it never ran since then and the coils are all in one
Old Jul 16, 2012 | 07:14 AM
Is the yellow spark at the plug or directly off the coil wire? If at the plug, then maybe the plugs are not the correct ones for your car, but highly doubtful. If grounding a coil wire shows the yellow spark, I'd try replacing it and see what happens.
SL2
May 30, 2024 08:34 PM
TinkerAB
Mar 28, 2012 06:54 PM
sammy_09
Jun 1, 2011 10:27 AM
br4nd0n
Dec 14, 2010 08:22 PM
callousparade
Jul 17, 2009 02:42 PM
