P1278, p1283 and p 0453 codes
Old May 18, 2026 | 10:29 AM
Just a thought, intake leak could push it out the exhaust. What else changed? Did the car ever run properly for you before the latest issue?
Old May 18, 2026 | 10:37 AM
Vanhernand's Avatar
Yes, it did run fine before it sat for those 2 years. It got extremely hot because of the lower radiator hose blew while going down the interstate. I had it towed home and there it sat. I misread your previous remark about the coolant flow "into" the inlet. I thought the leak you described to be external. I suppose it might be a head gasket/warped head(s)??? That's about all it could be, right? What a pain in the rear that is going to be.
Old May 18, 2026 | 02:10 PM
If you love the car and want to fix it, I would completely tear down the engine and have it checked for overheat damage. This is a complicated European designed engine. There is an engine oil cooler deep under the intake manifold. I am a retired career mechanic, and it took me several hours to replace the thermostat. Both heads are probably warped and I would much rather have one on the stand for that repair.
ricco4592
Saturn Aura
24
Apr 17, 2024 06:37 AM
Bonestock3ott
Jun 29, 2022 09:17 PM
drackett
Jan 2, 2010 07:18 PM
Cold1212
Jan 25, 2009 09:38 PM
arfalberg
Jan 13, 2006 01:34 PM
