Wet carpet on both driver and passenger side
Old 01-13-2018, 07:19 PM
tarndt7898's Avatar
Default Wet carpet on both driver and passenger side
I have a 2002 L 100 sedan and lately there has been standing water on both side floor boards, it started on the passenger side. I used a shop vac to clean it up there was that much water. I thought maybe heater core so took off some panels around the heater core. It looks like its a condensation issue coming from a black box looking thing directly behind the heater core. I can see water dripping off/ from the black box. I am not mechanically inclined at all just seeing if anybody knows what the issue is and if the dash is going to need to be removed to fix it.....thanks
Old 01-13-2018, 10:45 PM
As long as you don’t have a sunroof then the drain on the hvac box must be plugged. It drains out in the engine compartment under where the a/c hoses attach to the firewall. In the middle down low, it is black plastic 90 degree bend pointing down.
Let us know what you find.
02 LW300
12-03-2017 10:32 PM
jrj9871
09-20-2017 07:35 AM
djsted
09-13-2016 10:25 AM
pauluptime
07-02-2015 08:00 AM
JDC
06-09-2014 09:44 AM
Quick Reply: Wet carpet on both driver and passenger side
