I'm new here. But I love a saturn
Old Nov 15, 2019 | 06:37 PM
Fattyblow's Avatar
Default I'm new here. But I love a saturn
Hey this my first post but from just checking out the site uall really know these cars. Which is GREAT because I have serious issue. My wife has been running my work car east jesus. I have a 2001 l100 4cyl. I love it I've had it for about 5years. Last years fixed the dreaded security problem. No issues since. Tell about 2days ago. I was driving it and it just died. I mean everything shut down. While I was in motion the lights dash radio. All just died for maybe 2seconds. Then just came back on like nothing happened before I could pull over. Then today she called and said the car died. I went and checked it out no power no dome light, no dashlights, no crank. Nothing. Put the jumper box on it. Turned the key Nothing no signs of life. Checked the battery still good (just bought it about 6mths ago). Had to tow it home. Please help my mind is wracked
Old Nov 15, 2019 | 07:55 PM
Start simple. Check battery cable tightness and condition. Ensure connections are clean. Check the negative battery cable connection at the frame/block. Also ensure battery terminals are not fractured.
Also. What is battery V when holding the key to crank vs at rest?
Really sounds like you've lost 12V everywhere, and there's usually a simple explanation.
Old Nov 15, 2019 | 08:09 PM
The ground cable connects to a bell housing bolt near the starter. This is the ground for starting the engine. The body ground is on the inner fender between the battery and the windshield washer tank fill. The positive cable connects to the starter and the alternator. This the main cable to start the car and recharge the battery. The positive cable provides power to the rest of the car at the under hood fuse panel under the red flip up cover. This is also the place where you can jump start the car.
Old Nov 21, 2019 | 09:53 AM
Fattyblow's Avatar
Default Thanks
thanks for all your help. The fast replied gave me good ground to start on. The problem was a simple problem, it was the positive wire connection between the battery and fuse box. The power wire had a short in it. So when it was touch or moved to mich it would shut down the whole car. Thanks for all your help
Old Nov 21, 2019 | 10:41 AM
Thanks for checking back with your solution.
Andy
MrTwitchyMckat
Sep 16, 2017 08:38 AM
crsr1
Apr 25, 2013 07:53 AM
azertuche
Oct 28, 2012 09:43 AM
conniemay38135
Nov 25, 2008 08:04 PM
sirfodder
Jul 19, 2006 01:30 AM
