Ignition Cylinder
Old May 19, 2015 | 09:55 AM
spartan89's Avatar
Pardon my ignorance, but what exactly would I lube.
Old May 19, 2015 | 12:38 PM
Possibly the outside of the cyl, but people argue over whether it matters, collects dirt, finds its way to the electrical contacts of the ignition switch itself.
I use just graphite powder for the innards of the locks.
Old May 19, 2015 | 09:49 PM
Alpha Centauri's Avatar
hey folks --is there any recommended grease/lube for install (yes I remember he Ions)?
For the key slot, power graphite is best. O'Reilly has it in a little blue tube. For the cylinder cavity, when replacing the key lock cylinder, white lithium grease works best in my opinion...I use the spray can application.
Old May 21, 2015 | 07:30 AM
Dave4422's Avatar
I believe this guy is replacing his ignition switch in an L series. Hope this helps!
I've replaced the ignition cylinder in my S-series and the trickiest part was getting the code and making sure it's correct in the new cylinder. The tumblers will have numbers written on them. Write these down on a piece of paper and match them up with the new tumblers you'll get with your new ignition cylinder kit.
After a few months, I haven't had any binding or starting troubles with the ignition.
Good luck!
Old May 21, 2015 | 09:47 AM
Awesome Videos! Thank you Dave4422!
Old May 21, 2015 | 10:32 PM
I need to replace my trunk lock; I've had the cyl for three years but was afraid to mess w it as I have never done so and didn't want to end up w a disassembled broken cyl, an improperly config'd new cyl, and nothing to fill the hole in the trunk with (where the cyl goes). Maybe I'll give it a whirl
Old May 25, 2015 | 08:20 PM
spartan89's Avatar
The new cylinder is installed and everything works great! Car starts every time. Thank you everyone for your comments. I appreciate it a lot.
Besides a 2001 L200, I also have a 1999 sw1 that keeps me busy as well.
Old May 25, 2015 | 10:47 PM
Spartan,
could you please make a signature like ours:
First Name/Location (State)
Year Model Engine Mileage for all Saturns
Any other rides you wish to list
top right of page
clk your username>>UserCP>>Edit signature on left
Thanks.
SC2
Aug 4, 2022 07:30 AM
Apr 24, 2013 08:49 AM
wyndance
Nov 7, 2012 09:37 AM
mpace001
Oct 24, 2012 09:57 AM
sholt
Sep 23, 2010 06:37 PM
