Cv shaft passenger side
Old Nov 19, 2023 | 05:07 PM
Ddorsey682's Avatar
Default Cv shaft passenger side
Install a new cv shaft and I have about 1/2 inch between cv shaft and transmission. I’ve hammered and hammered. Is this normal
Saturn l100 2002 2.2
Old Nov 19, 2023 | 10:28 PM
I doubt it, which side and what did it look like before disassembly? There is usually just enough room to slip a pry bar between the axle and the transmission. The lock ring can get caught going into the side gear. Pull it back out and inspect the ring for damage. If it is destroyed try the ring from the old axle. The axle needs to lock into the side gear or the transmission will leak oil and die.
Old Nov 20, 2023 | 07:34 AM
Ddorsey682's Avatar
Ok thanks will check ring
Megs22
Nov 13, 2022 08:00 AM
steventech
Saturn L300
Sep 19, 2019 10:42 PM
Ohio_Guy
Jan 19, 2016 08:11 AM
Howard_Woodard
May 2, 2014 07:10 AM
alstar80j
Mar 22, 2009 07:13 AM
