2000 LS2 A/C Clutch Removal
Old May 3, 2015 | 12:13 AM
harsh.
I don't need ****.
Everything I need is in 3D, on the couch, taking a nap.
Go back to your Betamax and PBR. Rea said there's also some Boone's Farm in the shed near the bench were you sit to huff paint
Old May 3, 2015 | 09:18 AM
LMAO. I'm kicking Re out for revealing all of my secrets. That bitch!
Old May 3, 2015 | 11:39 AM
I replaced a clutch on my daughter's 3.8 Mercury Sable by unbolting the compressor and moving it around. There is not much room under that hood either.
Old May 3, 2015 | 08:34 PM
tooter1's Avatar
I was thinking that route too. This one is mounted right behind the radiator.
I can see it pretty good when looking through the wheel well at it but, still looks a little tight for tools.
Old Jun 14, 2015 | 09:02 PM
tooter1's Avatar
I replaced the compressor today.
That area is really tight, especially when the lines wont allow you to really do anything without removing them..
Old Jun 14, 2015 | 09:38 PM
I need to replace my compressor also. Looks like there will be lots of room if I remove the front head pipe back to the flange. How did you access yours?
Old Jun 15, 2015 | 08:27 PM
tooter1's Avatar
I just used the triangle opening right under the compressor. Didn't need to remove the exhaust at all.
I was able to get to the line on the back of the compressor from the top with a long extension and a u-joint.
Old Jun 15, 2015 | 10:39 PM
Thanks, I'll try that first. I do have a hoist so I can get it in the air.
catman021
Dec 28, 2009 07:30 AM
Dirty Mo
Jan 13, 2009 03:24 PM
chitownrepoman
May 5, 2008 09:01 AM
2000saturnsl2
Mar 16, 2008 04:28 PM
unseenworld
Jul 2, 2007 12:37 AM
