2000 ls sedan
Old 07-21-2012, 08:22 PM
jhernandez's Avatar
Default 2000 ls sedan
I have a 2000 ls and having a/c trouble. A/C was working fine last night and today would not come on. I checked relays, fuses, freon, all good, electrical power is good to compressor. The clutch is free but not spinning. Is this a compressor problem or a clutch problem? Thanx
Old 07-21-2012, 08:30 PM
If it's A/C: The first thing you need to do when working an an A/C unit is to put a set of gauges on it. Your welcome.
I'll ask one question..............does the heater and blower motor operate?
Old 07-21-2012, 11:23 PM
jhernandez's Avatar
Yes the heater and blower work fine. thnx for the reply
Old 07-22-2012, 08:54 AM
is the clutch getting the signal via the relay to engage?
Old 07-22-2012, 09:22 AM
jhernandez's Avatar
Default 2000 ls
Yes I also switched relays and re;ays are fine
Old 07-22-2012, 10:30 AM
Take a heavy gauge wire, and hook to the positive (+) side of the battery. Start the engine, and carefully touch the wire to the clutch control wire on the compressor. Does the clutch engage, and turn the compressor ??
Old 07-22-2012, 06:31 PM
Gauges high and low set
Attached Thumbnails 2000 ls sedan-ac-134a.jpg   2000 ls sedan-ac-temp-pressure-chart.jpg
Old 07-22-2012, 06:53 PM
jhernandez's Avatar
Tried jump wire and clutch did not engage, also no power to pressure sensor?
jhernandez's Avatar
thanx for the info I guess I really have to get me a set of guages!!
Old 07-23-2012, 04:37 PM
AutoZone will rent you a set of gauges.
Direct voltage to the clutch control wire should cause the clutch to engage
Quick Reply: 2000 ls sedan
