1993 SL2 Loud Vibration on left turn
Old Jan 22, 2013 | 09:15 PM
zero467's Avatar
Default 1993 SL2 Loud Vibration on left turn
My SL2 is making a loud vibration when turning left or going straight or when the car hits a bump in the that applies pressure down on the car.
The only time is goes away is when I turn right or if the weather is fairly warm (from what i noticed but that's not the case in Pennsylvania right now) I had the right front end wheel bearing replaced but the noise is still there and it sounds more like a grinding then a "wubwubwubwub" if that makes any sense.
Any thoughts on what it could be?
Old Jan 22, 2013 | 11:43 PM
Possibly a defective motor mount?
Old Jan 23, 2013 | 10:20 PM
zero467's Avatar
I'm going to replace the CV joint if that fails the motor mount is my next task
Old Jan 24, 2013 | 08:04 AM
Check your suspension. It could be a defective strut or strut mount.
Old Mar 8, 2013 | 04:24 PM
Claplume's Avatar
I'd say CV joint! If not that.. Check the boots in the joint. May be leaked out.. In that case. Replace the CV joint haha!
NG51
Nov 11, 2013 07:17 AM
shadetreemech
Apr 1, 2011 10:50 PM
nc_jed
Nov 19, 2009 09:51 PM
ford88mustang
Nov 15, 2009 07:17 AM
mjmurphy1955
Apr 25, 2009 07:06 PM
