01 L200 died without warning
Old Dec 11, 2007 | 11:33 PM
cali_saturn's Avatar
Newbie here so easy on the flaming...
Have an 01 L200 that never had any problems.
Tonight I was driving normally, made a left hand turn and BAM car dies.
Electrical still works, when she cranks its healthy electrically but seems
hollow.
Had a similar problem on my jeep, and it was the throttle positioning
sensor. Found another post here that hinted at that and showed how to
test for good fuel pump, but I was wondering if there may be something
else I'm missing? Any ideas?
Also, is there a way on saturns to check fault codes w/o a scanner? I
know on most of my past cars there was a sequence for turning the keys
or an actual diode you could turn. Is there something like this?
Thanks for the help. I work 24 hr shifts so I can't get back to her till
thursday. All ideas appreciated.
Old Dec 12, 2007 | 05:28 AM
HATCHET_SATURN's Avatar
does it seem to sputter at all when you crank it over?? try some starting fluid in the throttle body and see whut she does. if nothing then the TPS could be at fault..(one of many things) i dunno much bout readin codes on an 01 but im pretty sure a code reader is required
Old Dec 13, 2007 | 07:41 PM
changed TPS, changed CPS... any other ideas? How do I check spark with
that weird coil pack? Does this sound like a timing chain??
Old Dec 14, 2007 | 02:00 AM
HMM...JUST PULL A PLUG OUT AND HAVE SOMEONE CRANK IT AND SEE IF THERES SPARKY..DID YOU TRY THE STARTING FLUID?
Edited by: sw2cam
Old Dec 18, 2007 | 09:46 PM
PS: The next post with a tracker incerted will get the IP, e-mail, and user name blocked..............
Old Jan 4, 2008 | 06:57 PM
original007's Avatar
there is a timing chain recall for the 01 2.2l certain vin #s. Is there compressionEdited by: sw2cam
crsr1
Apr 25, 2013 07:53 AM
rah
Feb 9, 2010 11:32 PM
Missa81
Jan 7, 2009 08:43 AM
sl1driver
Jan 20, 2008 08:56 PM
burzurq
Mar 26, 2007 06:11 PM
