Water logged
Old 05-17-2022, 02:04 PM
johndough's Avatar
Default Water logged
Girlfriend drove through big puddle and killed her 2003 Saturn ion I changed the spark plugs and drained the oil and transmission fluid is next because It’s revving consistently at 4000 RPMs I’m just checking to see if there’s anything else I missing before I start it up and drive it again
Old 05-18-2022, 07:50 AM
Did you remove the spark plugs and crank it over several times to expel any potential water from the cylinders? If not, you might try doing that and checking the plugs to see if there's any water on them. BUT, if it's constantly revving at 4000 rpm, it sounds like a hell of a large vacuum leak to me. Did you get all of the hoses connected back in the right places before starting? And did you check the air filter and air box for water before starting it?
elephant
07-31-2021 09:11 PM
Saturn2020
01-21-2020 03:45 PM
Tinker1980
12-22-2019 02:19 PM
07-14-2018 07:42 AM
Morrowdr
06-16-2018 06:58 PM
Quick Reply: Water logged
