Rear Defrost...2007 Saturn...
Old Jul 21, 2014 | 07:36 AM
SolomonMan's Avatar
Default Rear Defrost...2007 Saturn...
All,
In the last year or so I have noticed my rear defrost is not working/or not working as well as it once did.
I am looking for the test procedures on a 2007 Saturn ION rear defrost.
The light powers on when pressed in the console area.
I am guessing the procedure is probably something like;
Check for voltage at the window plug and check continuity in difference areas of the window....but not 100% positive. I know there are repair kits out there....but not sure the whole procedure etc.
Anyone ever troubleshoot a rear defrost?
Thanks,
Chris
Old Jul 21, 2014 | 07:46 AM
You probably need to take a close look at the contact tabs and make sure they haven't come unglued from the glass. I've seen that happen. If they're okay, you need to check each "wire" across the window for breaks or missing segments. I've seen repair kits for them if that happens, but I can't recall where at this point in time.
jordan83
Saturn Aura
Mar 15, 2016 10:04 AM
danielpattonjr
Mar 28, 2013 09:51 PM
TRoop
Feb 24, 2013 10:29 AM
redvue
Dec 2, 2011 11:19 AM
JonJon3281
Nov 10, 2006 01:26 AM
