Oil guage installation on a 2007 Ion 2.2l
Old Dec 28, 2018 | 02:36 PM
Grbenda's Avatar
Default Oil guage installation on a 2007 Ion 2.2l
I want to install an oil gauge on my 2007 Saturn ion. Can somebody give me some pointers as to how to do it?
Old Dec 29, 2018 | 01:27 AM
Electric or mechanical will both require removing the factory sender and adding the necessary pipe fittings. You will need a nipple and a tee so you can add a second sender or tube to your gage. You need to continue to use the factory sender for the car to function properly. Oil pressure and fuel pump operation are monitored and controlled by the computer.
Old Dec 29, 2018 | 02:39 AM
Grbenda's Avatar
Thanks. I thought I would need to add a tee fitting and use the factory sender also.
Fasterthanyourcivic
Mar 23, 2017 01:45 AM
Avnav8r
Aug 8, 2016 11:37 AM
tazassape
Dec 31, 2014 12:04 PM
97SL2
Aug 18, 2009 08:04 PM
sation
Aug 7, 2009 05:13 PM
