2007 - Oil Cap Tube Leaking - Do I Need It
Old Mar 20, 2024 | 01:12 PM
Rock2110's Avatar
Default 2007 - Oil Cap Tube Leaking - Do I Need It
Do I need this extra piece that is between the engine and the oil cap? Doesn't have a tight fit & looks like oil can get out. Can I take it out & will the cap fit in there? I don't have the plastic engine cover.
Old Mar 20, 2024 | 01:50 PM
Can't tell without looking straight down into the hole, but it appears to have the threads for the cap in that top piece so I would say you would absolutely need it. Again, would need to have a view straight down into the hole to see where the threads are.
Old Mar 20, 2024 | 02:10 PM
Rock2110's Avatar
Thank you for replying. The neck is loose & can turn a little bit, but I'm nervous to try & take it off. Maybe another day. Kinda hard to get a picture of the inside. It looks like it's just a cylinder.
Old Mar 20, 2024 | 03:28 PM
So the threads are in the piece below? If that is the case, where is the oil leaking from. Please be specific. if that upper piece is just a cylinder, there should not be any oil getting up there in the first place if it's just the spacer. If the oil cap threads into the lower portion, again, there shouldn't be oil getting out from anywhere including under the cap.
Carefully inspect the oil cap to see if the seal on it is damaged. That's really the only way I could see oil getting up into the spacer. It should also be getting down onto the cam cover if it is leaking at the cap. They are not very expensive if you need to replace the cap. Probably can't find OEM but I would look. Whatever you find, purchase a new one not a used one as you want a brand new seal out of this
Old Mar 20, 2024 | 05:28 PM
Rock2110's Avatar
I'm pretty sure the seal is bad on the tube. The backside has space between it & the oil hole. I have an appointment Friday with my mechanic for a few other things. I'll have him check it out. Thank you for helping me out.
Old Mar 20, 2024 | 07:56 PM
I believe the spacer is just there for the the engine beauty cover. The valve cover is the same as the L series engine, the cap just screws into the valve cover. The spacer should just unscrew form the cover.
Old Oct 28, 2024 | 12:15 PM
That1dude's Avatar
I just noticed I have the same issue, 07 Saturn Ion-2 2.2. The part is called "oil filler tube," and mine is leaking very slightly from the part that should be sealed to the head. Wonder if this and what I just posted about my duct assembly hose is causing me to loose enough oil over time in between oil changes to make me have to add oil between intervals...? Probably a stretch but who knows.
Here are some pics, one of it seated and one with me lifting it to show how much of a gap there is. It also wobbles a bit and spins maybe a millimeter, but it doesn't seem like it could come out without forcing it.
Wonder what happened with OP...?
BlueJayWalker10
May 30, 2023 04:40 PM
Oct 7, 2020 06:21 PM
Dave4422
Jan 11, 2016 07:39 AM
Sperger
Sep 11, 2015 09:17 PM
KZinOKC
Aug 21, 2015 11:29 PM
