2006 ion 2 kinda hard to get in gear
Old 12-31-2019, 04:53 PM
krylonsleepin's Avatar
Default 2006 ion 2 kinda hard to get in gear
So today when i was driving i noticed that my 06 ion 2 (manual 5 speed) was getting difficult to go into first gear. im thinking it might be low on trans fluid but can not for the life of me figure out how to check the fluid level. also would anyone know anything else i should look at for this shifting issue?
Old 01-01-2020, 06:24 AM
DropDead's Avatar
Clutch master
/thread
Old 01-01-2020, 11:24 AM
Originally Posted by DropDead
Clutch master
/thread
I thought the same thing but the lady i bought the car from had that replaced a week before i bought the car. (she had receipts and i know the shop she went to as well)
Old 01-01-2020, 01:50 PM
How does it shift into reverse? Does it grind or go in smoothly? Where does the clutch engage? Is it close to the floor or in the middle? It may still have some air in the system.
Old 01-01-2020, 05:04 PM
Check the fluid in that new clutch master. IT may be dry.
Old 01-01-2020, 08:30 PM
DropDead's Avatar
Chances are its not bled correctly then. Otherwise it's the tob
Old 01-01-2020, 09:39 PM
id say it goes into reverse smoothly. its mostly just a pain to get into first.
Old 01-01-2020, 09:41 PM
how would i go about doing that? this is the first hydraulic clutch i have ever dealt with.
Old 01-02-2020, 07:01 AM
Typically, the reservoir for a clutch master is in the vicinity of the brake master cylinder. Both take brake fluid. Look and see if you can find them. Should be side by side, but this IS a Saturn, so I'm not positive. I'm sure DD or Andy can probably tell you. And if all else fails, check youtube.
Old 01-02-2020, 05:01 PM
I thought the Ions had a shared reservoir which exploded when stuff froze in place (a la Mandolin of days gone by)
Quick Reply: 2006 ion 2 kinda hard to get in gear
