05 Ion3 -- P0133 keeps returning ...USE AC DELCO O2 replacement
Old Nov 7, 2015 | 10:59 AM
dontnonottin's Avatar
Received the AC Delco o2 sensor from Amazon on Tuesday. Installed it, drove the car to & from work, check engine went out (on it's own) last night, passed emission test this morning. Thanks for your help guys.
Old Nov 7, 2015 | 02:20 PM
goaliemo's Avatar
Anytime man, glad it helped out
Old Nov 7, 2015 | 05:17 PM
Damn -- an AC Delco part that works as advertised.
Bosch is **** for S cars as well (use Denso OEM equivalent)
Bet AC Delco is a rebranded Denso.
Glad to hear you are back on the road.
Since it you never cleared codes, the light going out means part of the emissions drive cycle re ran the related emissions test. However, if it made any of the other monitor tests "not ready", you will not pass inspection until all of the monitor tests have been run. Not saying this IS the case, just MIGHT want to check I/M readiness status before returning to Inspection station
Autozone or similar should be able to check I/M readinesnthis while checking codes.
If there are any PENDING codes (Pxxxxp), I think you may fail. You may need to clear them and let the car rerun all drive cycle tests to get all of the I/M monitors ready.
All of the above is precautionary -- lots of maybes. Just trying to help
timmerz
May 2, 2014 08:50 PM
kensat
Oct 12, 2011 09:21 PM
wanderingjoe72
May 21, 2008 07:16 PM
90lxstang
Apr 5, 2007 03:05 PM
elkslayer69
Sep 29, 2005 06:25 AM
