05 2.2 cylinder misfire
Old Aug 13, 2016 | 02:22 PM
Grsulman's Avatar
Default 05 2.2 cylinder misfire
This one has me scratching my head. Two cylinders are cutting out a minute or two after starting.
Had a problem with two cylinder cutting out intermittently in March. Replaced the ICM and the coil packs with no luck. Ended up fixing the problem by greasing all the connections on the ICM good. Started doing it again two mornings ago but seemed to stop when it warmed up. Figured it was the nasty triple H weather we were having here in the northeast. It's gotten progressively worse and will start to misfire a minute or two after starting.
I replaced the ICM again, tested it by using a meter on the pins while someone cranked. I've also have done resistance tests on the coil packs. All looks good.
Any thoughts?
Thanks
Greg
Old Aug 13, 2016 | 08:29 PM
Thinking. I wonder if it is fuel not spark. Older sequential injection systems started as batch then switched to sequence after a few seconds on a cold start. Just thinking out loud.
Welcome, please tell us about your car. Ion, L200, Vue?
Old Aug 14, 2016 | 04:03 AM
Grsulman's Avatar
Thanks for the reply. It's an 05 Ion. A bit if a beater car but gets great gas mileage. I travel over 60 miles a day to work. 5 speed standard.
Any ideas on how to troubleshoot the fuel system? I've pressure tested it in the past.
Old Aug 14, 2016 | 10:10 AM
Does it misfire bad enough and long enough to set trouble codes? Can you identify which cylinders misfire? If so that is a start you can move injectors and see if the misfire follows the injector.
Old Aug 14, 2016 | 02:02 PM
Grsulman's Avatar
Good idea. I m about to go try to figure out which cylinders are misfiring by disconnecting the injector plugs one at a time.
Thanks for the replies
Greg
jenmetcalf5
Jan 3, 2018 08:12 AM
amn0025
Nov 18, 2013 10:51 AM
Drock
Nov 30, 2009 10:08 PM
AztecDan
Engine & Internal
Jan 5, 2009 08:09 AM
rchinny
Mar 7, 2006 11:19 PM
