Urgent!!1999 sc1 air bypass valve!!!!!!
I have a 1999 sc1 3 door and I have lost the original air bypass/diverter valve and no matter where I order one everyone keeps giving me the wrong part. The original part goes on with bolts but the one everyone gives me has studs and doesn't mount in the proper direction or location.. HEELLLLPPPPP🙏🙏🙏🙏🙏🙏🙏
Ps. Headlamps for the same model are also proving hard to find so if anyone has a lead on those that would be amazing.
Does this look correct? You can remove the studs if needed and you might be able to disassemble the valve and reclock the top part.
If not are you sure you have a 99 SC1? The headlight bulbs appear to be readily available for a 99 SC1.
This is the incorrect part that I keep receiving
Why don't you post a picture of the one you're replacing? Maybe that would help. Is it possible that what you're trying to replace ISN'T an air bypass valve and might be something else, like an EGR valve? Does it look like this? bay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw= egr+valve+for+1999+saturn&_sacat=33612&LH_TitleDes c=0&_odkw=egr+valve+for+a+1999+saturn+sc3+coupe&_o sacat=33612
chuckbattams
Mar 22, 2014 07:16 AM
