Urgent!!1999 sc1 air bypass valve!!!!!!
I have a 1999 sc1 3 door and I have lost the original air bypass/diverter valve and no matter where I order one everyone keeps giving me the wrong part. The original part goes on with bolts but the one everyone gives me has studs and doesn't mount in the proper direction or location.. HEELLLLPPPPP🙏🙏🙏🙏🙏🙏🙏
Ps. Headlamps for the same model are also proving hard to find so if anyone has a lead on those that would be amazing. |
https://cimg6.ibsrv.net/gimg/www.sat...f20bfe3bb.jpeg
https://cimg7.ibsrv.net/gimg/www.sat...8ff0e86b6.jpeg Does this look correct? You can remove the studs if needed and you might be able to disassemble the valve and reclock the top part. If not are you sure you have a 99 SC1? The headlight bulbs appear to be readily available for a 99 SC1. |
According to Rock Auto all Saturn S models from 99-2002 take that air valve with either engine.
Maybe the owner before you broke the studs off the valve that was on there and used bolts to hold it to the car
Reply to is this the correct part?
Originally Posted by 02 LW300
(Post 70420)
Someone may have substituted another part on your 24 year old car. This is the part that originally came on your car. I have done all I can to assist you.
Why don't you post a picture of the one you're replacing? Maybe that would help. Is it possible that what you're trying to replace ISN'T an air bypass valve and might be something else, like an EGR valve? Does it look like this? bay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw= egr+valve+for+1999+saturn&_sacat=33612&LH_TitleDes c=0&_odkw=egr+valve+for+a+1999+saturn+sc3+coupe&_o sacat=33612
