Urgent!!1999 sc1 air bypass valve!!!!!!
Old Feb 16, 2023 | 12:18 PM
More.like.uranis's Avatar
Default Urgent!!1999 sc1 air bypass valve!!!!!!
I have a 1999 sc1 3 door and I have lost the original air bypass/diverter valve and no matter where I order one everyone keeps giving me the wrong part. The original part goes on with bolts but the one everyone gives me has studs and doesn't mount in the proper direction or location.. HEELLLLPPPPP🙏🙏🙏🙏🙏🙏🙏
Ps. Headlamps for the same model are also proving hard to find so if anyone has a lead on those that would be amazing.
Old Feb 16, 2023 | 08:38 PM
Does this look correct? You can remove the studs if needed and you might be able to disassemble the valve and reclock the top part.
If not are you sure you have a 99 SC1? The headlight bulbs appear to be readily available for a 99 SC1.
Old Feb 16, 2023 | 08:41 PM
According to Rock Auto all Saturn S models from 99-2002 take that air valve with either engine.
Old Feb 17, 2023 | 12:04 AM
Maybe the owner before you broke the studs off the valve that was on there and used bolts to hold it to the car
Old Feb 18, 2023 | 12:22 PM
Default Reply to is this the correct part?
This is the incorrect part that I keep receiving
Old Feb 18, 2023 | 08:27 PM
Someone may have substituted another part on your 24 year old car. This is the part that originally came on your car. I have done all I can to assist you.
Old Feb 19, 2023 | 08:20 AM
Why don't you post a picture of the one you're replacing? Maybe that would help. Is it possible that what you're trying to replace ISN'T an air bypass valve and might be something else, like an EGR valve? Does it look like this? bay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw= egr+valve+for+1999+saturn&_sacat=33612&LH_TitleDes c=0&_odkw=egr+valve+for+a+1999+saturn+sc3+coupe&_o sacat=33612
bretylium
Nov 21, 2021 09:53 AM
slivasaturn
Mar 9, 2021 08:06 AM
RaceyRaider3
Jun 10, 2015 11:04 PM
chuckbattams
Mar 22, 2014 07:16 AM
rhaslam
May 1, 2006 12:32 PM
