Saturn sc2 95 Quad driver module
Old Mar 30, 2012 | 02:51 AM
fixedangles's Avatar
Default Saturn sc2 95 Quad driver module
I have a issue with my 95 Saturn. I can start it up and drive it for about 5 to 10 minute before it acts up.
I can be going down the road and it will die instantly. No cutting out, just a straight shutdown. Its like someone hit a off switch. After it dies it will not start again for at-least one hour. I had my friend come out and hook a machine up to it since i have failed to combat the issue. I changed the gas filter and hollowed out the cad convertor thinking one of those options would fix the car. Neither one did.
I received 3 codes:
Code 26- Driver Module Fault
Code 27- Flag Quad Driver Module Fault
Code 48- Info Flag Reference Pulse Error
Anyone know if any of the three codes could be without a doubt causing the above described problem
EDIT
Also i was told to maybe look into the Coolant Temp Sensor .
I have noticed that the fan never kicks on.
Thanks
Old Mar 30, 2012 | 01:31 PM
The QDM is internal PCM that controls various components from check engine light to cooling fan to EGR solenoid & pugre solenoid. If it comes on as soon as you start the car most likely the EVAP purge solenoid is the fault.
Thats a guess not a fact, maybe stopping at the dealer will save you money in the long run.
Old Mar 30, 2012 | 11:47 PM
I paid 9 bucks for the Coolant Temp Sensor and changed it out and it seems to fix the problem.
Thanks
Old Mar 31, 2012 | 11:56 AM
Old Apr 1, 2012 | 01:08 AM
i thought i had this problem put in the bag, but i was wrong! It ran fine for a couple hours then the same problem came back.
Could i possible have a weak fuel pump? After the car dies it wont start immediately and it back fires when i attempt to start it. If i let it sit for an hour or so it will start right back up as if nothing is wrong.
This car is really starting to wear me slick.
Old Apr 1, 2012 | 08:58 AM
check
cooling fan relay
A/C clutch
CCP Solenoid (Charcoal canister Purge)
EGR solenloid
Coolant hot light
Upshift/Shift to D2 light
Speedo Operation
I posted last night but it seems to have vanished
chavnutsmcchav
Feb 17, 2014 04:19 PM
98sc2w/potential
Mar 24, 2013 12:12 PM
cspotkill
Dec 30, 2012 11:19 PM
Digit4lPyro
Feb 27, 2010 07:56 PM
Icedmojo9
Sep 17, 2007 10:45 PM
