Ignition Cylinder Lock??
Yes I have. Usually theres difficulty with the ignition cylinder before the key actually gets stuck. You''ll have to remove the shroud and if you''re luck, when you press the little button to remove the cylinder, it''ll slide out. If not break out the drill/grinder and have at it.
wyndance
11-07-2012 09:37 AM
