Drivers Side Power Window does not work
Old Feb 16, 2013 | 09:45 PM
N1NJ4JESUS's Avatar
Unhappy Drivers Side Power Window does not work
I just bought by first car yesterday, a 2002 SC2. I went to tim hortons today and when I tried to open my window, it didnt work, so I had to open the door to order. It was working fine this morning. The passengers window works and so does the sunroof (not sure if the sunroof is relevant), and the switch makes a noise when I press it. Theres also another noise Im pretty sure is coming from the door. My mechanic is on holidays until the 25th so I was wondering if anybody knows a way to fix it without taking the car apart. Thanks
Old Feb 16, 2013 | 11:14 PM
Stop double posting.
well, I'd venture to guess it's either the switch, the window binding in the tracks, or the motor itself. Me thinks door panel removal is required to see what's going on.
So no, there is no way to fix it without taking it apart.
Old Feb 17, 2013 | 06:25 AM
Agree with Derf.
Old Feb 17, 2013 | 08:18 AM
Ayup - I agree as well --- me three.
Get the panel off, and see what's going on inside --- or open your door until the 25th, and let your mechanic do it ....
Old Feb 17, 2013 | 11:01 AM
N1NJ4JESUS's Avatar
Ok, sorry for double posting. If I take off the door panel is there any easy things to check and fix without buying any parts over like $10 at Walmart or something?
Old Feb 17, 2013 | 01:52 PM
You won't find parts for your window problem at WallyWorld. You remove the panel, then try to operate the window. If its making noise like you posted, then the problem should be obvious ...
Old Feb 17, 2013 | 03:57 PM
Wamart, no but you should be able to get everything you need at Burger King. You can get a McDouble at that other place
karljesse
May 25, 2013 07:54 PM
john doe
Apr 19, 2013 08:28 PM
SC2
Apr 1, 2010 06:36 PM
branlee33
Feb 8, 2008 06:25 AM
juggalo2929
Feb 25, 2007 04:32 PM
