Coolant Leak Need Help ASAP
Old Feb 4, 2013 | 05:38 PM
'98 Saturn SC2's Avatar
Default Coolant Leak Need Help ASAP
I have a coolant leak and it looks like its coming from the area of where the hose (the upper driverside hose) connects to the radiator. Its leaking pretty bad, it ends up spraying onto my trans and that side of the engine bay. It looks like its coming from the hose by the way the coolant is sprayed in the bay. Any information or ideas help. Thanks.
Old Feb 4, 2013 | 08:28 PM
Pull the hose off and check to see if the rad is cracked there or if the hose has given up the ghost after 15 years of service. Sometimes they get soft, sometimes they get brittle and then just don't seal properly.
And please catch the coolant that gushes out and dispose of properly. No need to kill neighborhood pets.
Old Feb 6, 2013 | 12:07 AM
Derf has you looking in the right area, but you are the one with eyes on the problem. Remove the hose, and look ...
Old Dec 28, 2019 | 08:34 AM
Steve Millbourn's Avatar
Default Electrical Tape
I found a crack in the hose under the fastener when mine leaked. I just wrapped it in electrical Tape and cranked it down. You could also try cutting the rip off if it's close to the edge.
Old Dec 28, 2019 | 05:35 PM
Ah, another necropost
case closed
mikelife85
May 19, 2014 01:45 PM
maidel
Sep 26, 2013 11:16 PM
LS2 V-6
Sep 21, 2012 05:36 PM
cordytess
Aug 27, 2009 07:52 AM
trysten
Jan 30, 2009 11:42 AM
