A/C Clutch not turning
Old Mar 3, 2022 | 10:41 AM
dougonbay's Avatar
Default A/C Clutch not turning
OK.....here's a picture of the pressure/clutch sensor switch with the connecter off. That's the part I want to replace. It's on the upper right side of the fuse box. It looks straight forward to remove and replace. There are 2 wires to the connector with labels - a dark green "A" and light green "B" . Light green "B" has 12+V when the A/C is on high and the A/C button is lit. Unable to test V out from dark green “A” but no V to the clutch. This part may not be the problem but it's low labor and cost to eliminate it. As always, thanks for the assist.
SC2 1.9L A/C pressure switch
Old Mar 3, 2022 | 10:50 AM
dougonbay's Avatar
Apologies for the picture size.....I couldn't figure out sizing and will take a closer look for next time
Old Mar 4, 2022 | 08:11 AM
Looks like you need to undo that ground strap and clean that connection up while you're in there. That's a potential bad ground connection.
Old Mar 4, 2022 | 09:52 AM
dougonbay's Avatar
OK.....this is it - GM part # 21030824. A friend of a friend got it from GM dealer. It's discontinued and my Google search came up blank with no one having it available. Now what? Suggestions?
Old Mar 5, 2022 | 07:02 AM
Try adding refrigerant to the system to see if you even need one.
However, you seem obsessed with replacing a part not in production that may or may not be bad, and can only be tested by raising the system refrigerant pressure anyway.
Knock yourself out.
If you ask for help, we offer what we believe to be the next logical step in troubleshooting. You don't have to agree with the answer nor do you have to perform the step.
But if you are discarding our recommendations, stop asking for suggestions.
I'm done here
dotman
Mar 5, 2022 08:06 AM
Dtruck1
Sep 8, 2013 10:34 PM
MrNormanT
Oct 20, 2010 05:01 PM
bucky katt
Aug 16, 2009 11:45 PM
snellenj
Jul 17, 2009 07:39 AM
