Alternator
Old Jan 22, 2009 | 04:25 PM
geezerw's Avatar
ripped the wires from the connector on the alt. Anyone have a wiring diagram ? plug reads S F L P need the color code for the F and L pins
93 sc2
thanks
john
Edited by: geezerw
Old Jan 22, 2009 | 05:15 PM
Well, here is what my notes say:
Three wires are involved in that connector ... BRN-WHT wire should connect to terminal F; the BRN wire should connect to terminal L; the remaining wire should connect to terminal P. Terminal S is unused.
Old Jan 22, 2009 | 05:30 PM
geezerw's Avatar
only have brn-wht and brn in the harness ? so will go with them.
Thanks [img]smileys/smiley1.gif[/img]
john
Old Jan 23, 2009 | 08:54 PM
The third wire is the output wire from the alternator back to the battery ...
Old Jan 25, 2009 | 10:58 AM
Low Saturn's Avatar
S - Unused
F - Brown/White -Ignition
L - Brown - Battery Charge Tell Tale
P - Unused
Charging Circuit Operation:
The battery supplies voltage to the generator at all times. During engine start-up, the I/P cluster performs a bulb check by illuminating charge telltale for three seconds. The PCM supplies 5 volts to the generator L-terminal to initiate charging. The system charges the battery and provides power to the vehicle electrical devices. The PCM can increase idle speed to boost generator output if the battery voltage drops below specification. If the charging circuit malfunctions, the PCM signals the I/P cluster to illuminate the charge telltale.
The only other wire involved with the alternator is the fusable link that goes from the charging terminal on the alternator to the constant positive on the starter. Then from there it goes off to the battery.Edited by: Low Saturn
Old Jan 25, 2009 | 11:11 AM
Thanks for the clarification there, Mike ...
You said much more clearly what I was trying to say
Old Jan 25, 2009 | 11:20 AM
Low Saturn's Avatar
Its the least I could do sitting here on a lazy Sunday morning in my underwear.
Old Jan 28, 2009 | 09:40 AM
geezerw's Avatar
Got a replacement connector from a wrecking yard. Key on I have bat voltage on both pins OK ?
john
Old Jan 28, 2009 | 09:44 AM
Low Saturn's Avatar
Sounds good. Does the car start?
Old Jan 28, 2009 | 10:39 AM
geezerw's Avatar
Yup just making sure before installing new alt.
thanks
john
jimmyslide
Nov 19, 2008 11:21 AM
albrightwv
May 14, 2008 09:51 AM
x0kalie
Aug 27, 2007 03:56 PM
brianfgonzalez
Aug 20, 2006 08:38 PM
djking112
Oct 28, 2005 06:04 PM
