2000 engine in a 1999 sc2
Old Jul 16, 2008 | 09:58 PM
rosscoe49's Avatar
I have 1999 saturn Sc2 dohc engine that is blown up. I can get a 2000 dohc from a sc2 same vin code low mile engine. My question is can it be interchanged easily? I know the block is the same but the head and intake are different. What are the differences ? What problems? I am assuming the head is also toast on bad engine, so just swapping the block is a last resort. Thanks
Old Jul 17, 2008 | 09:46 PM
sturgis1957's Avatar
Just went through a similar swap only I have a 2000 and it had a bad engine and I swapped it with a 99. There are a few differences in the wiring harness as the MAP; MAF; IAC; TPS;Knock sensor and Camshaft sensor are different as far as the harness ends are concerned. If you can get the 2000 engine with the harness and make the appropriate changes so it will match the harness you nhave it made in the shade. My swap whilst not without hitches work flawlessly after all was said and done .One other thing the cold air intake from the throttle body is also different .Prepare fora few mods here.
Old Jul 22, 2008 | 08:16 PM
rosscoe49's Avatar
Just a quick note to Sturgis 1957. Thanks so much , that was exactly the information I was looking for . I just needed to know what is different with these engines . Thanks again. Rosscoe49
Old Nov 9, 2008 | 11:04 AM
tjw961's Avatar
What were the mods on the intake? Do the bolt patterns match so you can just use the 2000 on the 1999 block?
Cary the Car Guy
May 1, 2013 08:30 AM
gtokidd
Nov 12, 2008 05:10 PM
kloppk
Jul 14, 2008 06:27 PM
kloppk
Jun 2, 2008 04:05 PM
MengusDew
Apr 4, 2007 02:39 PM
