Engine Problems, Sensor out?
Old Nov 9, 2008 | 11:05 AM
tigerdragon's Avatar
So I have a SC1 1997. It starts cold but the radiator fan is always on. After warming up turned it off and let it sit for 5 min. It was hard to start, had to press gas pedal 1/4 to 1/2 way, like it was some how flooded. Then there was a gassy smell and the fan was still on.
The codes I pulled were:
P0100
P0110
P0115
P0116
P0120
Any help is much appreciated.
Thanks
Old Nov 9, 2008 | 06:14 PM
Low Saturn's Avatar
Bad coolant temperature sensor and/or connector.
And those codes you pulled are not even listed in the Saturn Factory Service Manuals. I dont know how you got them, but the have norhing to do with a Saturn.Edited by: Low Saturn
Old Nov 10, 2008 | 01:46 PM
Ayup ...
Fan running continuously, starts OK when cold, hard starting when hot, smells gassy, screwball codes ....
Engine Coolant Temp Sensor (ECTS) A two-wire sensor located on the block of the engine, on the driver side. About $14 or $15usd at Autozone or similar. Be sure the new sensordoes not have an exposed resin tip, as these types of sensors do not last long. The connector for the wiresis a plastic piece that often fails too, so replace it as well (another $14).
Get some teflon tape, and wrap the threads of the new sensor so it will seal well. Also, make the replacement when the engine is COLD - no need to get scalded.
sep25
Jul 24, 2011 10:56 AM
usjosgun
Apr 17, 2010 08:13 PM
screamin77
Jul 20, 2009 08:26 PM
Faster=Better
Dec 28, 2008 07:37 PM
betinaq
Jul 14, 2005 01:23 AM
