Fuse Box Purchase Advice
I am in the market for an under hood fuse block for my car. It will not replace OEM, so it can be from any car, and year, any model, etc etc. What I am looking for is one that has at least 5 12volt relay sockets and at least 10 fuse plugs with ratings up to 25amps for some plugs. It can have more or less than 10 plugs for fuses, maxi and standard blade fuses. It just MUST have 5 relay plugs at the least. The more the better for relays and to an extent, the fuses. I doubt I will come a cross one with too many fuses. The compatible relays must be low cost and easy to obtain.
Again, this is something anyone can answer if they have ever come across a fuse and relay block that will fit my needs from the information given and that they can remember what vehicle it was. The car it comes from does not matter, the more options to choose from the better. Photos appreciated, this will be used to last a lifetime so I never have to change the block again. So I always will have room for expansion. There's no way I am using all plugs anytime soon.
